Oil for R245fa
hello everyone,
I need to use R245fa as refrigerant working fluid. But I am not sure which lubricant should be used for R245fa. The compressor I am planning to use is originally for R290. The oil type is 100cst. My question is:
Can this lubricant for R290 be used for R245fa? If not, which lubricant can be used?
Is there anyone have some experience on this issue?
Thanks for your help/
Re: Oil for R245fa
Hi John
pentaflourapropane is compatable with synthetic pag 220
but the 'fa' version of 245 is specifically designed for electrical circuit cooling and is normally pumped liquid oiless
and has a primary circuit to cool the liquid, example R404a
R's chillerman
Re: Oil for R245fa
Thanks, chillerman.
I totally agree with you. R245fa also is used in ORC cycle.
But I use R245fa as the working fluid to test the performance of the ejectors, which will be applied in the refrigeration systems. So I need a compressor.
The compressor is there which was for R290 testing in the lab. So can i use it directly for R245fa?
