Hi i want to try elm programing for eev tev , multi evep, multi comp etc
any body got some old units and progmerer not in use for sale or giveaway
please get in touch
please get in touch
Need help with one unit programed or a hand held elm unit for sale and data sheet with fault codes and parameters
I know i am late as i have found out that honeywell dont do elm any more
Can somebody help in next couple of days??
one of our lads got brand new handset online somewhere.. will ask him where he got it
managed to get handheld unit it only showes set temp and blind times . cant get in to full set up mode con any body walk me through ?
what model of controller is it ?
tuscan5 190797-ybt and universal 8 chanel alarm 190797-yav
are these units job espacific ? i thought thy could be programed to do different jobs
i want danfoss akv valve with air on & off and gas on & off and forsed deftost by externel timer
Hi Cyotec,
For AKV EEV you want an EEV or EEC control card. I cant recall the YBT doing EEV but I might be wrong as its been a while?.
The EEC range of controllers has a non adjustable alarm threhold, specifically set up for Somerfield but it depends what you can get hold of.
Most if not all controllers do Local or Remote defrost commands.
The 8 channel monitor is a card capable of reading 8 temperatures concurrently if set with different alias.
What specifically do you want to know?
Hope this helps.
Mark
