Older Type Reversing valve coil
Hey peeps,
It's probably been mentioned before but I'm trying to track down one of the older style RV coil with the larger diameter. It's out of the good ol' Arkair AC's ducted systems with the horizontal blow cond fans.
I have a burnt out one here, looks about 15mm shaft hole.
Info on the coil is as follows -
Controls Co. of America
Model 279
208/240v
10w
199822-001
I know there was some fella floating around selling them for some ridiculous price.
I'll grab a pic if needed but I think you guys may have been in the same situation.
PS: Customer won't leave me alone *HELP*
Cheers :)
Re: Older Type Reversing valve coil
Try the Sporlan solenoid, possibly available from Airefrig at Silverwater in Sydney. Pretty sure they fit a larger stem.
i was looking for one a while ago, couldnt find one ANYWHERE.
ended up replacing the whole rv valve.
Thanks fellas, picked up a sporlan type from airefrig. had to sand the shaft down and whack it on with a hammer (shifter). All good :)
