Hi All,
I am looking for some supplier, who can help me in getting a liquid Refrigerant Pump for R245fa refrigerant for my ORC cycle.
Amit Saxena
Hi All,
Amit Saxena
A small magnetic drive sealed pump similar to a hot water circulation pump, bronze or stainless steel body, they usually come with three speed selections.
Hi Amit,
I am building my own ORC system rated at around 1.5kW electrical output.
The pump I have selected (but not yet tested) is from Fluid-O-Tech.
Supplier is
http://www.depcopump.com/datasheets/...-Tech/tmfr.pdf
I am using the TMFR100 model which will pump about 0.04kg/s or 2L/min of liquid R245fa.
The pressure differential I am working with is from 287kPa to 1700kPa (Absolute).
Where are you getting your R245fa refrigerant from as I am having a hard time locating a supplier for less than 5kg quantity.
Solarjoules
