anyone on here done EAL level3 course at Technique Training in chesterfeild ??
hi all
has anybody on this site attended a course at Technique Training in chesterfield ??
and have you completed your level3 course work ??
please help if possible
dean
Re: anyone on here done EAL level3 course at Technique Training in chesterfeild ??
dean_thomas
hi all
dean
Dean you can't expect people to do the course for you!!!!!!
Ask what you need and we'll see what we can do.
All the best
coolrunnings
Im stuck with the last question,
Draw a detailed schematic with all pressure reading of a two stage industrical plant
anybody any ideas best books etc to look for advice?
Where is this last question?
An introduction and a brief explanation would be polite!!
A two stage industial plant.............
Because some systems work at low temperature the pressure
differance between the suction and discharge is too great foer it to be
done in one compression process.
So they use a two stage or compound system.
One compressor pumps low pressure refrigerant to a second compressor
which then completes the compression process.
On some systems that two stage / compound process can be done with one
multi cylinder compressor. The low pressure cylinders deliver intimediate
pressure to the high pressure cylinders.
All the best
coolrunnings
