I'm loking for a simpel program where jou can get the same information like on a Pressure/temperature slide .
Download CoolPack.
[quote=sammycclass;205263]Hello
:off topic:
I have Thermo King with a RD II shut down problem.
Don’t know what to do any more I did check some wires look ok. Check oil and water ok
Starts some times shuts down ride away and sometimes runs for a few minutes when I adjust the rpm screw to high rpm is ok so I get the fallowing codes 71 77 61 sometimes code 74 as well please help
Thank you
Or Solkane from Solvay
For Sammycslass, nobody will answer you post if you don't do the efforts to post it in the right section
code61 =low battery voltage try fitting a slave battery and run on test
I did check all battery connection and power and ground all ok will start and turn off so I check contacts all ok check diesel in to fuel filter all ok check oil and water all ok removed circuit board cleaned all contacts with contact cleaner because I have seen some light mildew on the circuit board removed & reinstalled back now control panel in cab will not light up if I turn on black switch on position it will turn on and off buy itself so don’t know what to check any more please help.
Thank you
I have a pocket refrigeration calculator from DUPONT witch can do all T/P conversions in a split second for all common used gases. I got it from a local refrigeration spares company that cells DUPONT gases. So try your local gas supplier.:eek:Keep on Topic PLZ
www.exactchargehvac.com
Click on ExactCharge Calculator on left hand side.
Click on Conv key for SI Mode.
Instructions are also available.
Click on ExactCharge Calculator Icon on left hand side.
Click on Conv key to convert to SI Mode.
Free.
