Re: air conditioning noise
Was the sound a swooshing sound,
its possible it is the unit changing from heat to cool if its a heat pump in auto setting this happens when the unit shuts down and the reversing valve opens equalising the system pressures
i cant explain the noise, sorry. it happens 5mins into the heating mode. the customer says the wall mount sounds and the outside unit can be seen throwing water out via a cloud of water from the fan area.
this is the best i can explain it from the customer point of view.
Yes, that would be the defrost cycle starting.
I appreciate that you are 'new to this' but is your customer getting their monies worth?
i am new, but this isnt my job. im simply helping out a friend. thanks for asking.
Defrosting. Now, why it happens after 5 mins in heating, that's strange.
tichyt
Maybe.. an r22 conventional, gets to its heating setpoint then shuts off followed by reversing valve equalising.. mike.
hi, to close this thread the noise was from the fan hitting a piece of wire. all sorted now. thanks for any help given.
