Re: expansion valve with MOP
If water is issue, than you could heat valve body with hot fan to see if that melt ice in valve and restores normal superheat.
What is valve make and model #?
Every few weeks you said. It looks to me as ice in valve. Maybe filter-drier is saturated.
Hi mate
I have not got the model of valve, it is starting to become more frequent, every few days!! Moisture sight glass suggests system is dry!!
The hole valve and coil are iced up apart from external equalise line, may be because exposed to ambient however valve is also @ 20c...
Thanx
