Hello everyone. We need the data on this compressor precisely its strength to 0, -5, -10, -15, -20.
Nema tog modela. Provjeri oznaku.
There is no such model # in Copeland data base. Find correct model #.
Correction, it is such model number but without "R/12" part!
Thanks team Copeland replacement for him is 15x R 134
D= DWM Copeland
K= 2 cylinder
S= long stroke
L= 9,1 m3/ displacemant at 1450 o/min (50hz)
A= model variation (A-P)
-= separator
15= motor size (15 or 20 )
X= POE oil
http://i37.tinypic.com/34nfsio.jpg
What is use of your compressor? By asked conditions i suppose MT (medium temperature) refrigeration.
http://i37.tinypic.com/3026hox.jpg
Milk cooling tank was used to 1200l.
Can you replace it DANFOSS-Maneurop MT 28?
Milk cooling tank was used to 1200l,but the day bringing 500l of milk.
I want to replace 150 R/12 DKSLA DWM Copeland is defective for the new DANFOSS Maneurop MT-28 to R22.
:rolleyes:
I want to change the DWM DKSL 150 R 12 for the new Danfoss Maneurop MT 28 R 22
Koji češ plin koristit?
It is not clear what refrigerant you plan to use.
If you are going to use R22 instead of R134 or R12 than for same capacity as original compressor (if that is original one) you need MT22 compressor and new TXV like TEX2 with 02 orifice.
Mislim da si takav odgovor već dobio na Fanzi.
I'll take the R22, which goes with the MT 28 course that will change the valve, filter and nozzle
Excuse the spelling, I write it using Google Translate
Hello everyone. We need the data on this compressor DWM DKSLA 150 R/12 Copeland precisely its strength to 0, -5, -10, -15, -20.
