Multideck Chiller Evaporator Fans Make Unknown
Hi Guys.
I attended to an unknown multideck chiller today. There are two axial fans with 150mm mounts. They are the square 230V cased fans, similar to those in a PC.
There is no data plate on the unit and the customer has no details of the unit.
The fans did not start but by spinning them up with a screwdriver they started to run, very slowly.
Can any one recomend a supplier in the UK that can supply a replacement fan? I found lots on line but not that go up to that size.
Would the environmental conditions call for a specific type of fan?
Thanks guys, hope you can help me out.
Phil.
Re: Multideck Chiller Evaporator Fans Make Unknown
Try RS Components, they do that size and above, start here..
http://uk.rs-online.com/web/search/s...8mm#breadCrumb
Thanks Brian.
RPW found a pair in stock so I fitted them today and all seems well again at the moment.
I do have an account with RS any they have a complete range in stock.
Cheers!
Phil.
