Which type of chilled water strainers do you recommend. The system that I need to add these to are 5" dia. Copper nickel material and each loop is 270GPM per chiller with 3 total chillers in parallel.
How dirty is your water?
What does your designer recommend?
What does your supplier recommend?
What does the strainer manufacturer recommend?
