Hi!
Our Clint has a trane 100TR chiller.What is the maximum quantity of cold air(In CFM) they can get from that chiller. Is there any rule to find out the quantity of air from chiller capacity.
Hi!
You can get an unlimited amount of cold air from that chiller the only limitation would be the fancoil(s) you connected to it.
Say that it's installed up by the north pole...
Nah we need a bit more info I'm afraid:
First, we are talking about a chiller i.e. a machine that cool water or another fluid?
If so what are used to exchange heat with the air?
Cold air? What we need to establish is your expected temperature differential. I.e. if the air going in to the unit is 30˚C then what do you expect the air leaving the unit to be.
What ambient conditions are we expecting this unit to operate under?
And
So
On.
