Designing Roll Bond Evaporator
:confused: I want to use roll bond evaporator in my vissi cooler (Show case Refrigerator). I contacted the manufacturers of the Roll Bond Evaporator with Refrigerator size (capacity and dimensions), ambient and required temperatures, compressor specifications etc and asked them to offer suitable roll bond evaporator. But they are asking me for a drawing and design of the evaporator. Can anyone help me in designing a roll bond evaporator.
Re: Designing Roll Bond Evaporator
Originally Posted by Munzar Ata
:confused: I want to use roll bond evaporator in my vissi cooler (Show case Refrigerator...Can anyone help me in designing a roll bond evaporator.
Why? How would you have enough space in a showcase? No back access required? You would need lots of surface area unless the case is for display only and the doors rarely opened.
If the showcase was not designed for refrigeration, does it have insulation and a vapor barrier? Have you thought about condensation run-off?
Rog
Rog
The showcase is a vertical refrigerator with a glass door in front and I plan 2 install RB evaporator with the rear wall. That does not occupy much space. It is meant to be used as display of cans / bottles (4 degrees C to be maintained) and a drain at the bottom for draing away condensate.
Any suggestions as how to design the RB evaporator. I'm already producing this unit with Inner Al body wraped with Cu evaporator coil.
Munzar Ata
We can design for you, for that we would like to know your application and dimensions of visi cooler
for designing roll bond evaporator we require your application and dimensions of referigerator
Munzar Ata
we can supply you the roll bond evaporator, if the order is given to us.
vakilnikhil - I work for a company that designs and makes solar panels and am working on a product where we are looking to use a rollbonded heat exchanger - please could you give me your details so I can contact you?
Also,
Munzar Ata - could you please tell me the name and contact details of the roll bond evaporator you have found?
Andy
Hi Andy,
You can contact CGA, an Italian manufacturer of Roll Bond panel (the world leader). Their website is: cgaspa.it
Their email address is in the website.
If you send them an email with the explainations of your company/project/needs, they should be able to help you.
They already have a big experience in Roll Bond solar panels manufacturing.
If you have no answer in the next few days, just let me know and I'll help you.
for any rollbond requirements talk to hawco technical phone 01483869069 or go to
all the w's.hawco.co.uk
