Beko Fridge freezer - freezer temp issue
Hi there
currently have an issue with my Beko CDA539FX fridge freezer. I recently swapped the door to open from the other side,andsince have had an issue with the freezer temperature i.e. it isnt cold enough. Foolishly I swapped the door without first turning it off...and since have followed the instruction in the manual to turn off for a minimum of four hours to allow to settle, then turning back on. Still however the temp isnt low enough. The freezer fan is operating and it is freezing (ice cubes are eventually freezing) but what few other things I have in there arent - loaves of bread and suchlike. Any suggestions for what I should be checking? Thanks in advance.
Re: Beko Fridge freezer - freezer temp issue
just a suggestion! are the seals on the door you have swapped round sealing properly to the fridge ? if they are i would firstly defrost the fridge fully and then restart the fridge but dont put owt in it till after 24hrs .
Okey dokey - Ill give that a bash. Seal seems fine - had a good fondle round it and seems good. I shall report back if solved. Cheers ;)
