Can anybody advise what is the recommended interval for overhauling the top end on a York Compressor, model no. JL642?
Whenever your short of work otherwise 5,000 hours
Thanks for that Yorkie10.
greetings, I have a problem with a machine model YSCACAS2 york, protected by high oil differential pressure, and check the calibration of the Transom and accurate, as verified with gauges in ports where are the type of oil transducer.que takes this compressor which was manufactured in 1995 and has already made him Overhall has approximately the same this year.
thanks
greetings, I have a problem with a machine model YSCACAS2 york, protected by high oil differential pressure, and check the calibration of the Transducer and accurate, as verified with gauges in ports where are the type of oil ?transducer.que takes this compressor which was manufactured in 1995 and has already made him Overhall has approximately the same this year.
thanks
Hello friends, pls give me compressor overhaul manuval. JG642-GS50-46.
