3 seperate daikin multi split systems cooling a large office. All 3 systems shutdown not showing any fault codes except a icon on the controllers showing that all 3 systems are being controlled by a primary controller. As far as I am aware these systems are independant from each other. If I switch off one of the 3 systems at the breaker the other 2 will run fine, doesnt matter which one I turn off. Any ideas ???
