rex (zanussi) mobile split
Wonder if anyone can help.customer brought in rex (zanussi) a/c mod-RCB 14S. comps gone.willing to spend money.have had no luck with suppliers of unit nor electrolux/zanussi (they say its a grey import).comp details -no name.but the following info. C-R 110H5H (tse)
10 076 R22
the rest just electrical info.
surfed net with the CR number, found Russian site giving a reference to a Sanyo comp SAP-C127GH.But have not found any UK sanyo comp supplier.(rang sanyo uk gave me dist' numbers but they need sanyo unit info)
regards
Re: rex (zanussi) mobile split
from the numbers i hazard a guess at 14k btu
and this seems to bear out that nicely ;-)
http://www.domestic-airconditioning....ssirex140s.htm
try srw and just get an equivalent rotary and adjust the pipework
cheers
richard
I cant comment on what the other guys think, but I get asked to look at about 10 portables every year, though mostly the B&Q junk boxes. I used to try to find parts, but in my opinion these are a throw away item, when something fails on one of these things, take it down to the local refuse site. For little more than the price of a repair (Dont forget that you will guarantee that repair) they could have a nice little wall mounted inverter heat pump fitted.
Have you tried your local wholesaler?, they should be able to match up a new compressor. The question is why did it fail in the first place?
Best place for them in my opinion is the skip
thanks to you both.allready spoke to srw,all the boffins away on holiday(lucky for some) wil try them again next week.think it might be 1.1kw.if i get any further then i will post info.
cheers.
