Oil separator will not block all the oil, so that's not sufficient whereby my initial question remains.
I'm only a hobbyist. Maybe I should be asking you how to solve this problem.
What do you mean whit forced convection boiling (I can imagine what you mean) and how will you do this?
I'll be using jet impingement on the a micro grooved enhanced surface. I'll talk about this more late, if need be.
Have you figured out what the cooling capacity will be taken into account losses of lines ,pumps etc for your desired HP/LP combination? And will this meet your requirements?
The heat load itself will not be more than 0.25kw. I was told the only heat transferred to the fluid from the pump will be due to mechanical in-efficiency of the pumphead. The capacity of my compressor at -35C is 400w, because I'm using R410A I should get a increase in capacity. Basically I just bought the largest compressor my budget allows.
I do use cycle analysis in coolpack quite a bit, so everything should workout.
What kind of pump will you use? You will need a very little capacity. Viscosity of the refrigerant will be much higher then usual found
It's a Oberdorfer model N.2000E.S16, helical gear pump of all bronze construction, with neoprene mechanical seal. Will deliver 7.5 L/min at 1.5 Bar total differential head, with an NPSHR of 0.7m. This pump may not be used though.
And also, not everyone can build any chiller but you still need to prove that you can build a liquid overfeed.
I never said I could build one. If I could build one, I wouldn't be here asking you these questions. It's just in my hobby I see a lot of chillers, but so far no liquid overfeed systems.
What you need is a level indicator on the liquid separator which 'demands' liquid from the receiver to maintain the same level in the separator.
Is this achieved through the use of a LSF?
