I have a Daikin VRV with FXSQ ducted indoor units. The system was just installed this past November - during the heating season.
With one indoor unit the fan was a little loud when it got to High speed after the Hot Start Control so I set the fan speed to Low using the Service Mode 44. I used the Service Mode to set the fan speed because I only have one remote controller and wanted to make the change on just that one indoor unit. But, I found on really cold days with it in Low speed it could not keep the room warm enough so I set it to High fan in Service Mode 44.
Now I realize that unit will only operate in High fan no matter if it Hot Start Control or I select Low fan on the controller for all units. Is there a way to reset the controller and that one indoor unit so that it is not locked into always being in High fan?
Thank you.
