Guys, try this out
Evening all,
try this link out, its a number thing and only takes about 10 seconds to do
Seriously freaky how they work it out, if anyone knows the secret, dont keep it and let me know how its done.
Seen this sort of thing before but it sill amazes me each time
latte
http://www.regiftable.com/RegiftingRobinPopUp.html
Re: Guys, try this out
it works when you pick your number and look at it on the screen you always go to that number with your mouse,i think this is how it works as if you work out your number and put the mouse pointer over a different number it comes up with that box
No matter what number you pick, after you do the sums it can only be a few possibilities on the next screen (multiplies of 9)
all it does is chance all these numbers at the same time giving an illusion that it has hacked your brain.
Chillin:):)
Yes all the possibilities are covered with the same item. If you look at the board without picking a number you will find the same item on every combination you can work out. These are on 9,18,27,36,45,54,63,etc.
