Hello all.
Was wondering if anyone can give me a capacity on the following compressor.
WANBAO
AL15007N07A.
r134a
I think it is about 1/4 hp.
Thanks in advance.
Hello all.
WANBAO
AL15007N07A.
r134a
Thanks in advance.
1 hp = 746 watts
1/4 hp = 186 watts or 0.8 amps @230v
1.69amps @110v
Hope this helps
en.wanbao-compressor.com.cn/en/Exhibit/home.asp
try here
cooling capacity for AL150 is 398w. You can say it's 1/2HP. ASHRAE
and it happens to be my product. you can ask me any question about wanbao compressor.
Hi Jenny, do you know of a UK supplier of this compressor? We buy alot of your equipment (Nisbets) and i'm in need of some replecement Compressors.
AL150, it is mean that this compressor have displacement 15cc.
If you use for fridge unit you can use CAE2414Y Tecumseh product using R134a or CAE2424Z Tecumseh produsct using R404a but have to change the capilary or expansion valve to R404a. If you using for chiller you can use CAJ9480T for R22 or Z for R404a but it is imposible because AJ family from Tecumseh have bigger size than AL150.
I hope it can help u.
