Re: Cold weather charging
Some use portable small gas-fired torches. I don't suggest that for safety concerns, but it may be the only choice in absence of a plug.
i use a drain line heater around cylinder works well
I use one from this company, warms up really quick and it`s 115v
www.airserco.com
Glenn
It might sound silly but got a portable hob 1500watt 230v and i put a thin metal plate over it and then the large gas bottle on top ,i charged 140kg r22 in 3 hours at outside temperature was 2c the system was already part charged
Rubbish Bin full of hot water is what I use, if available. Just submerse the refrigerant bottle and your away.
dsp
an old stick on crankcase heater mat stuck on to an back support belt.but at -15F i'd be tempted to but it under my jacket and sod the refrigerant
Thanks to all who responded to my situation. I have inquired about both nike123 's Robinair unit and glenn1340's airservco heater. Pricing always a concern but will gladly pay if it works. Know both companies' reputation so can't go wrong. Thanks again for the leads. Have a good day !!
I use a domestic electric blanket, ( type that heats your bed up ). Sometimes if it's very cold I'll wrap some armaflex sheet around to avoid heat loss. For me this is 230V (UK).
I apologize for the delay in responding to how your advice turned out but serious family medical situation took over my time. Happy to say all is well and improving every day. I checked out both nike and glenn's suggestions and went with glenn's only because of availability and ease of ordering thru local counter. I am , again , grateful for the help and will always try to return the favor to all who need help. Thanks and best to everyone !!!
go to Graingers and type in band heaters, there are 9 pages of them
Rich
