Air conditioning ceiling cassettes
I quite rarely get involved with the installation of ceiling cassettes as I'm a service engineer, and deal with quite a bit of refrigeration as well as air conditioning. The thing that I always seem to take quite a while with is hanging ceiling cassettes. Usually I remove the tiles etc, put the threaded rods in and make a frame from channel before hanging another four rods to hold the cassette, but I'm sure there must be better ways than this as I seem to take quite a while to get the cassette centred. I know this probably sounds a bit trivial but any better ideas would be gratefully received.
1 Attachment(s)
Re: Air conditioning ceiling cassettes
We do it like drawn in this raw sketch. We need 4 standard channels (omega channels we call it) of 2 m.
The 2 channels whereon the unit is attached is not fixed on the 2 upper channels. They're just laying on the upper 2.
With this system, you can slide almost 60 cm in each direction, enough to fit in a tile ceiling of 60/60 (cm)
The threated rods are parallel fixed so you can regulate the height very easy (just release the parallel 'nuts' movng up, adjust the height of the 2 rods a little bit and slide the parallel nut down again)
