Daikin unit
Hi can anyone tell me anything about these types of Heat pump,RSEY10KJY1, RSEY1BKJY1, I have tried The Daikin Web site but I have found nothing.
Both of the above are outdoor units, and I was interested primarily in the pipe work sizes, three pipes all of differing size.
Can someone tell what they might be?
Sparrow
Re: Daikin unit
Hi Sparrow,
You need to register on the Daikin Extranet to access their range of documents.
http://extranet.daikin.co.uk/login.htm
1 Attachment(s)
Re: Daikin unit
Hi Brian,
Thanks for your reply, I followed the link, but the server goes into an error? I can clearly see where it asks for you to register,on the extranet but can go no further. does the photo help.
Re: Daikin unit
Hi Sparrow
Sounds like you have never come across a VRV system before.
Have a read here for the basics
Re: Daikin unit
RSEY10 exists but RSEY1B is a typo of some sort, probably another 10hp unit
Pipe sizes are (mm) 28.6 , 19.1 , 12.7 or 1 1/8 , 3/4 , 1/2 in old money (suction , discharge , liquid)
