help needed with a question
hi all im new here. i bought a 2nd hand samsung american fridge freezer .. worked perfect for nearly a week and now i have found that the freezer part is flashing minus 24!!
and that my things are defrosting
any one help please ..
we didnt get a manual on how to lock the temps
help needed asap freezer defrosting
my previous post was asking why my freezer is defrosting and the temp moving up and down..
its samsung american one model sr s2028cvw
Re: help needed with a question
Flashing number is a fault. Turn the power off for a few min and turn it back on.
See if you get a fault code (tiny single segment on the display) or whether it fires up again normally.
But you have a fault that requires a service guy out to fix.
fan, heater or thermal fuse is my guess
paul h is correct you have fault with the defrost side so as he says you will need defrost sensor thermal fuse and maybe the heater
