the evaporator fan in the fridge side has been getting noisy and since returning from holiday the led display was flashing and the fridge was warmer and ice is starting to form inside also how on earth do you get to all off this???????:(
Same as all the others, evap fan iced up due to system not defrosting, or insulation getting water logged.
Nearly every samsung mentioned in the forum has the same fault, so there's heaps of info if you search.
Pull the inside evap cover off, if the coil is a block of ice, you have a defrost sensor, t/fuse or heater element problem
the fault for all these is defrost sensor failure need to replace it, can supply u one if needed
yes no problem pm me and will sort it
He won't be able to PM with only 2 posts.
ok thanx for that have to email me then airkool@hotmail.co.uk
