SteinarN
I have the same kit. (actually two of them) It did a big ahh to me. I did use clamp on probes earlier, but didnt get reasonable readings with them. Cold suctionlines seemed always to be warmer than they could be, showing several degrees of superheat even when flooding the evaporator. Liquidlines seemed to have several degrees subcooling even when they couldnt contain subcoold liquid.
That changed when i started to use that kit. I guess faulty temp readings is the reason so many argue they get subcooled liquid at the condenser outlet in units with receiver. When you have a receiver with 50cm pibe between it and the condenser outlet, it is absolutely 100% impossible to have any measurable degree of subcooling if the receiver isnt full of liquid and you dont have uncondensables in the system.
