Component Analysis For R134a Domestic Refrgerator
Hello everyone,
I am an under graduate Mechanical Engineering student, and right now working in a project, for which its required that i will have to assemble all the components of the refrigerator R134a based, since i am very much new to this field, i dont have much practical experience, i need your help in component analysis and component matching. It would be very helpful for me if u can tell me various sites and e-books related to it.In short How to start the assembling of a refrigerator?..Thanks for your Valuable time.
Re: Component Analysis For R134a Domestic Refrgerator
So you would like us to perform your research for you then ?
No not all, i am just asking for your guidance, tips, etc only. I told you I am new to this field,and internet is just one of the medium to start my research work, so I did.
sbkvelocity
Try this
http://www.danfoss.com/United_Kingdo...The+Fridge.htm
http://www.sciencemuseum.org.uk/obje...s/1971-66.aspx
http://www.mtprog.com/ApprovedBriefi...1_2007May2.pdf
taz
Thanks a lot for inputs Taz..I am aware of the basics, i just need help in the balancing of the system, that is what type of compressor is suited to what what type condensing unit, dimension of the capillary tube, in short I have to assemble the refrigerator and hence need to have knowledge about balancing of the system.
Then go there:
http://tinyurl.com/2fv2vq
You have plenty of tools for your needs there, and by studying every tool you should learn more about selection and balancing of refrigeration circuit components.
Thanks a lot buddy, u send me just the right information I was looking for...thanks a lot.
hii
i 'm also working on it
i want to ask a question to u
can this sites help can u read it
hi MR. india where r u
can u find ans of ur reply me
thanks
Dear Jahangir,
This is danfoss site, you can check out the danfoss official website for these selection and calculating tools.
akram
HI MR . AKRAM
I 'M VERY HAPPY TO SEE A PAKISTANI IN THIS SITE
IN WHICH COMPANY U R WORKING I'M WORKING IN LAHORE
OK COME TO THE POINT
WHICH SITE HELP FUL TO ME RIGHT IT AGAIN
THANKS
JAHANGIR AHMAD KHAN
ASSISTANT ENGINEER
HAIER PAKISTAN LTD.
Now Io Want To Calculate The Heat Load In Freezer
If I Put 6 Liters Water In Freezer How Many Btu Required To Make It Ice
Thats My Question
Could The Danfoss Site Help Me Regarding This Problem
Can
Ans Me Fast
I'm Waiting For Reply
SPEACIALY TO MR. JOSIP
Jahangir Ahmad Khan
Lahore Pakistan
jahangir.ahmad
Thats My Question
Can
Ans Me Fast
Jahangir Ahmad Khan
Lahore Pakistan
For your calculation you need more information.
What is entering temperature of water?
What is desired temperature of Ice.
What is desired time for ice production.
What is heat gain in freezer from surrounding.
What is heat gain in freezer from fan motor and lighting.
What is Ice form
What is air circulation heat gain from opening freezer
HI NIKE GOOOD AFTER OON
THANKS FOR INTREST
Ans= 20c
Ans= -18c
Ans =24/hr
ans= i can't understand it explain it details (ambiant temp)(43c)
ans=there is no fan and light in freezer (dircet coolrefrigerator)
What is Ice form
Ans= i can't understand it explain it in details
Thanks and best regards
jahangir ahmad khan
Lahore Pakistan
jahangir.ahmad
That is calculation of heat ingress from surrounding in freezer at designed ambient and freezer temperature.
Because the freezer is in surrounding that is at higher temperature than his internal temperature and because your insulation is not perfect you must add that heat to total cooling load.
That mean that you need to calculate how much heat is coming from surrounding thru freezer insulation panels at your operating temperature and highest ambient temperature.
Than you maybe have defrost heater. Again, if any part inside generate heat ,you need to add that to calculation.
What is Ice form
If you are going to freeze one ice cube, or 100 small cubes, there is no same time for freezing them, because ice is heat insulator, and core of one big Ice cube will freeze slower than core of small cube. Amount of heat load is same for both but time for freezing is not the same.
When you open door of freezer, you allowing some amount of hot air to enter in freezer. That is heat load which evaporator need to extract. Therefore, in your calculation, you need to add that to total load at evaporator.
Do you have any tutor (teacher, older engineer) in your company? :eek:
I ask this, because these questions you should ask him, and he should be able to explain them to you in much easier way and at concrete examples.
Unless, he is deaf, blind, dumb and speaks Hungarian language.:D:D
mr.IBRAHEEM
i can't take a usefull information from these sites
http://tinyurl.com/2fv2vq like this
how could i find the btu/hr
i'm confused
help me
speacialy to MR.josip
thanks in advance
jahangir ahmad khan
lahore pakistan
jahangir.ahmad
This is same on English:
http://tinyurl.com/586gnm
hi every one
dearest MR. NIKE
in this sites i'm just found the software there is not enough information about how to calculate the btu/hr
can u tell me another site
thanks
i'm waiting for your reply
jahangir ahmad khan
lahore Pakistan
Dear Jahangir, my impression is that your knowledge about physics and other disciplines needed in this industry is not suitable for tasks you are challenged with.:(
It is obvious that you don't have basic knowledge how to convert one unit system to other unit system and that is something what any engineer need to know when you wake him in middle of night.;)
Today, with help of internet, there is no excuse to some engineer that he could not convert any unit in other unit, no matter of his expertize.
It is just matter of basic engineer knowledge as it is calculation as 2+2=4.:eek::eek:
Don't be dejected by this taught, but I think that you need serious tutoring.
HI GOOD MORNING MR.NIKE
I'M VERY HAPPY TO SEE YOUR COMMENTS ABOUT
I'M AGREE ABOUT WHAT U SAY
BUT ONE THING REMEMBER IF U NOW THAT HOW TO CALCULATE THE
BTU/hr?
why u don't tell us
i'm now the basic of refrigeration for your kind information if u any no#
(cell no#)to call i 'll ans u on the spot about basic
now guide me how to find the btu/hr
this is my last request to u
please understand my problem except telling me to hair any teacher
thanks for your kindness
jahangir ahmad khan
lahore pakistan
1 Attachment(s)
jahangir.ahmad
BTU/hr?
why u don't tell us
Ok I give you example:Attachment 2141
GOOD EVENING
BANDLE OF THANKS FOR U MR.NIKE
YOU ARE SUCH A GREAT TEACHER
I 'VE NO WORDS TO SAY THANKS
THANKS AGAIN
AND BEST REGRADS FOR YOUR WHOLE LIFE
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
