Dear guys,
I need to recover R23 (with synthetic oil) into a recovery cylinder.
Can I use a normal recovery unit?
If NOT what is the proper procedure?
Any help is appreciated.
Thanks a lot.
Dear guys,
Thanks a lot.
Depends on the quantity to be recovered but, use a recovery cylinder that has a good vacuum on it to suck the gas out.
yes just watch your head into bottle and temp of bottle i put 2k in a recovery bottle today of r23 that has a ten k capacity and that was enough you should really have a reinforced bottle as that what 23 comes in a reinforced bottle
I had a cascade system with 2kg of r23 and was told to use a vac pump on it. So what i did was i made afitting which went on the exshaust side of and in to large recovery cyclinder and suck it out
