bath room reclaim heat pump
Hi sirs
There are many bathroom(as business) in our place. Most are using coal boiler. the waste water can reclaim heat by heat pump. And 1kwh can produce hot water as 2 kg coal does which is a good deal for money and environmental protection. I'm not sure if there are heat pump product for this application. I know there's no in my country. it's maybe a business chance.
welcome any input
regards
LC
Re: bath room reclaim heat pump
There are projects - heat pump centre . org - I have read about reclaiming the heat from sewage pipes - but i was thinking about small scale/domestic situation. Hot water from bath, basin, shower, washing machine, dishwasher - plenty of heat wasted. the only problem I can see is heat exchanger - it would clog up or will become inefficient because of sludge forming on the surface? Any ideas?
I read some experience with compressor ZR18
R134a 230V Cu condenser , evaporator from split.
