Re: Manitowoc Ice Machine
First off, check your operating pressures during the run time. Clean all the water parts, especially the sensing probe. Is the compressor shutting off from its contactor or is the contactor still energized.
Manitowac has excellent handbooks at a reasonable price which show the circuitry highlighted during the various parts of the operating cycle. I believe you can get them free online for all current models in pdf format.
Found the problem. It is the little things that you sometimes overlook. The discharge cooling water line had a shut off valve in it and the valve was almost closed, This was making the compressor shut down on a safety. Unit works great,
Thanks for the help Dan. :o
Ice machines can be frustrating. Glad you found the culprit:)
