Already solved problem (another again)
We once had problems with an oilpressostat safety device (OSD)
On the packs we mostly uses (Profroid (Carrier)/France), Profroid mounted them just like Bitzer with a bolted bracket besides the oil pump.
Because it was a negative pack, there were also head ventilation fans mounted.
From one of the OSD, the cover of it was broken or removed (I don't remember this) and the airflow of the fan of the head ventilation was just enough to cool down the heating element whereby the OSD was unable to trip off when it was needed.
We had therefore a broken compressor (no oil in the sump) mounted a new compressor and had a broken compressor again after some days.
The client argued that we hadn't checked his OSD during service some months before. The problem was a faultyTraxoil (electronic oil level system)
Since then, all the racks for this client where changed and we had to order packs now with the OSD on a separate panel.
Better this way Marc?
