Re: 10 commandments of NH3
Know all the reasons that your compressors can cut out. Many of them are safety cut outs and simply cancelling an alarm and initiating a restart should not be the first response.
The great number of gauges and instruments on your circuit are all there for a reason and often are not enough. Be aware of what each measures and what each should read and be wary of any unexpected deviance.
Lift a head phone as you walk through a machine room. Odd sounds should be thought of in terms of "something ain't right". Loud sounds from piping definitely means "something ain't right".
Ten Commandments (or more) of NH3 Refrigeration Safety
(1) While Ammonia is a wonderful gas for refrigeration and finding cuts, it is a poor choice for breathing. Always have your PPE at hand when you find yourself in a situation where it may be released.
(2) Never trap liquid. As soon as it realizes you have it contained, it will escape and show you its affinity for the water leaking out of the holes the pipe created in your anatomy when it exploded.
(3) Know all the reasons that your compressors can cut out. Many of them are safety cut outs and simply cancelling an alarm and initiating a restart should not be the first response, or it may become your last response.
(4) The great number of gauges and instruments on your circuit are all there for a reason and often are not enough. Be aware of what each measures and what each should read and be wary of any unexpected deviance.
(5) Lift a head phone as you walk through a machine room. Odd sounds should be thought of in terms of "something ain't right". Loud sounds from piping definitely means "something ain't right". The Chance of being deaf is much preferred to the chance of being dead.
(6)
Thanks Steri!
I added a word or two..... Hope it gets long enough I can't keep up ;0}
I will post it in the engine room !
Ammonia does not like dilettantism
gesi
Had to look that one up
RANGER1
Had to look that one up��
Me too.
Rob
Had to look it up also!
"The meaning of DILETTANTE is a person having a superficial interest in an art or a branch of knowledge : dabbler. How to use dilettante in a sentence. Synonym Discussion of Dilettante."
