USA coil Software (problem )
when rating a condenser in usa coil software, there is CFM for axial fan.( my axial fan has a label for example 4000 cfm).
which one is correct for cfm in software:
1-SCFM
2- ACFM
3- determine cfm with a velocity meter device
if i dont have a Velocity metering device, what is the reasonable number for CFM.
thanks
Re: USA coil Software (problem )
Hi, hsn ...
hsn157134
1-SCFM
2- ACFM
thanks
Hope this will help a little ... not sure what to suggest you but for sure try to calculate with the best options and with the worst ... to see the difference ...
https://www.pdblowers.com/tech-talk/...fm-actual-cfm/
... calculations are not the numbers only ... sometimes (mostly of time) it is a game ...
Best regards, Josip
