I have just seen an add for a new R407F which is supposed to be equiv to r22 but slightly better at low temps. I haven't seen anything in writing...has anyone?
From the Agas site.
http://www.agas.com/product/ProductI...tion.php?id=91
taz
Product Name:R407F (Genetron Performax LT) http://www.refrigeration-engineer.co...ation_line.gif http://www.refrigeration-engineer.co...no_product.gif Description:
HFC refrigerant (zero ODP) manufactured by Honeywell
A patented blend of R32, R125 and R134a
Higher capacity than R407A at low temperatures
Lowest GWP of all commonly used blends
ASHRAE number R407F
A1 safety classification (non toxic and non flammable)http://www.refrigeration-engineer.co...ation_line.gif
Applications: Potential R22 replacement in medium and low temperature applications, thus eliminating the need to carry multiple cylinders in the van Physical Properties: Pack Sizes: United Kingdon: Returnable Cylinders
See also
http://www.google.co.uk/url?sa=t&sou...bGj1mT1We6U4Kw
taz
Have read in one of the trade mags that its been tried in a few supermarket systems and worked well.
Thinking about giving it a try in some milk cooling systems as a few have low and high temp evaps on same units, so would need a low temp drop in to run the icebank and then a high temp one to run the tank, this sounds like it will cover both.
Jon :)
Hi friends ,
Can R407F can be used in systems which were earlier designed for R22(which are presently in operation with R22) ?
Thanks for your cooperation.
