FTx25 strange noise from indoor unit
Chaps
got some older 2013 indoor units 2 out of 150 which are making a strange motor type noise. but we have changed the stator and both bearings but still the same..
link to video:https://youtu.be/V8mSsOl2Y_E
has anyone had similar and what was the solution?
Re: FTx25 strange noise from indoor unit
If that is BLDC motor, than probably problem is in control electronic!
nike123
that will be the indoor unit pcb then?
Guess you would have sussed this but anyhow, couldn't be sure from the video but sounded a bit like the fan was out of balance with the drumming noise?
Tayters
on going
as soon as you switch off the noise stops but the fan keeps spinning..
As Nike has suggested, probably induced electronic noise from faulty PCB.
