I have a cardinal double door back bar cooler.
The compressor has stopped kicking in when the thermostat goes live.
If you tap the compressor it will start up.
What could be a possible solution.
Many thanks for any responses.
Richard.
Richard.
sounds like a brocken - loose wire, whatever you cannot do anything with a hermetic compressor< if all the electrics are ok< new one re-quiered
INstall an automatic tapper
Had last week a technician that wrote on his job sheet "hit the oil seperator on the head with a hammer, so that the oil can come back". Cannot punish him, he is too honest. (had to change the wording on the job sheet).
Looks like tapping could change the refrigeration industry!
AH, fame at last :D
i have a special offer on a nice rubber mallet, specifically for compressor resetting, no need to bother with them gauges and things:o:o
love to start sunday with a laugh.....................
try golden pages or maybe someone on here might be close to you?
al
hi
check relay & over load loose wire
It will be the tiny Aspera compressor on a back bar bottle cooler, the electrics burn out on those regularly.
I agree with the relay.
