US Hoshizaki Ice Machine to Africa. Will it Work
Hi Everybody,
I am looking to get a Hoshizaki Ice Cube Machine (KM1300s). Voltage requirement is 208-230/60/1 from the US. I want to take it to Nigeria. Voltage available is 240v/50/1. Will it work?
Has anyone done something similar or have an idea?
Any particular thing to know about the wiring? All other info will be appreciated.
Re: US Hoshizaki Ice Machine to Africa. Will it Work
It will work.
the difference in Hz is 17% so that how much the capacity will decrease.
You also have to check what the ambient temp the machine design to.
Maybe to try the 60 Hz compressor work at 50Hz through a (the so ubiquites) frequency inverter ?
call 1-800-233-1940 which is Hoshizaki. ask for tech support. They will tell you what you need to know.
