In the present application, the "containment" between the two
spaces seems well defined (when you are standing there). Will
making the "cold" room colder (in effect making the air heavier),
possibly decrease the current effectiveness of the air movement
at the opening, or would this relationship NOT be proportional
compared to the current application?
I found a graph which would indicate normal infiltration under your initial conditions would be somewhere around .15 tons per square foot. And increasing to about .2 tons per square foot of opening if you dropped the inside temperature to 20 deg F. (Stoecker, "Industrial Refrigeration Handbook").
