Does anyone know how to break down the model number on copeland compressors? Application, size (ton/hp), oil type, voltage rating. Any rules of thumb I can use to cross one model comp to another with a different (even slightly) model?
jcool.
I have not found exactly what you want.
But the link below is pretty neat.
a you can search this parts link and fin details of all sorts of DWM COPELAND AND PRESTCOLD COMPS.
Try it and see!
Cheers Grizzly
http://parts.ecopeland.com/IPP1/index.html
This is for copeland scrolls
What do Copeland® Scroll™ refrigeration compressor model numbers signify and what refrigerants are approved for use with them? ANSWER : Copeland® Scroll™ refrigeration compressors (such as ZBxxKA-PFV) are designated by a "Z" in the first position of the model number. The second position determines the application range (B = high/medium temperature, S = medium temperature, F = low temperature). The third and fourth positions represent the first two digits of the capacity of the compressor at its standard rating conditions and the fifth position gives the multiplier for the capacity (C = 100, K = 1,000, and M = 10,000). The sixth position designates the compressor's model generation. If there is a seventh position before the dash prior to the electrical designation, it will be an E (Polyol Ester oil) or an L (shipped less oil). If there is nothing in the seventh position, the compressor has mineral oil in it. Electrical designations (such as PFV) are the same as other Copeland® models. For picture diagrams, go to Copeland's Online Product Information (OPI) database and search nomenclatures by product category.
I dont know for others.
Good posts Chunk
cool,
I just finished a Copeland Copelametic compressor specification table and put it on the web. I hope you find it useful.
Just click on: http://www.hvacrinfo.com
and follow the link to Copeland Compressor Specifications "Data" in the right hand column.
regards...........powell
please check first the capacity of the old compressor and supplied voltage. if it compatible then you could modified it.
in refrigeration systems; check your drier, txv, and refrigerants if they are compatible, the oil you can use suniso 4gs, 3gs etc. depends on the capability of oil in refrigerant you use.
_____________________________________________
brian
SAMSUNG Tech. Support
