410-A is an azitope refrigerant wich is a blend.
Then how does the manufacturs say it has an even leak rate?
If it does have an even leak rate why do you only charge in liquid form?
I know that mixing mineral and polyol ester oil is bad,
but what is the result, what does it do exactly.
Polyol ester is water absorbant but why cant a vacume pump remove the water, 28" Hg water should boil out?
Will the oil realy absorb water threw plastic?
How mutch mosture can it absorb?
How do you test the mosture content?
How fast will it absorb, or how much is too much?
Sorry I am a horible speller
