Re: Ice Cube Maker SWITCH
I have just flicked the Switch i mentioned ,, Checked it after a few minutes, and noticed the Ice cubes have been Ejected and the Ice Maker has Re-filled to make more Cubes,, The Problem now is ,,Is this the Switch for the Maker, And because i keep switching it both ways, Which is ON and which is OFF...
rebels59
Switch it the opposite way to the one when it did not work.
Leave it for 24 hours and see if the thing works.
If it does not switch it the other way and run for 24 hours. If one works, well done. If it does not work then there is a problem with the control of the thing and only by manualy switching the switch, gets it to opperate.
See what happens.
Cheers taz.
if it is fix make your plumbing monthly so you can avoid another failure with your ice cube maker SWITCH because I also plumed my ice cube maker SWITCH monthly and nothing bad happened.,.,
Dear sir,
I am an ice machine sales girl in China and if you need more cube ice makers, pls tell me and I will offer the very good one;
Lisa zhu
Email: lisa.zhu@sinocean.com.cn
