Hi Guys,
I am atfer some input regarding a refrigeration design that one of our "electronic enginners" has decided to come up with and any feedback on wether it will work OK would be appreciated.
OK, we Have 2 x condensors that he has piped in parrallel, (not water cooled) 1.9 kw each and a compressor of 4kw.
He has gone from the discharge pipe into 3/8s 0.7m up he has Tee'd off into a 5/8s pipe,( Note this is a 90degree bend in both directions) 6 inches from the tee "left and right" he has then reduced the 5/8s into 1/4" pipe, and they run into the condensors.
There is no flow control valve in the line
My question is would he be better of pipeing the system in series, giving better sub cooling and less flashing off, or would his system be best.
Thanks in advance for any replies.
BR John M
