Hello,
We have an air chiller unit. The block diagram and orginal device's foto are available in the attachments.
What do you think of the structure of coolant???
Thank you in advance...
Hello,
Probably pipe coil or maybe finned-pipe coil.
Soryy!!!
The following figure looks at the air stream is incorrect.
Not Air flow rate(air outlet) : 110l/m
This is the value that must be... Air flow rate : 1100 lites/minute (air outlet)
