Hi everybody,
does anyone have a drawing of a KAB S2/27 ?
KAB is Kühl Automaten Berlin, which is now part of Grasso.
Grasso will not give any information :( .
Thnx,
Gerben
Hi everybody,
Thnx,
Gerben
Hi Gerben.
Before 15 flights am much used to work with compressors KAB (Ilka), manuals lost, will heavy is obtain. Good luck to you.
Hi Josip,
thank you for your quick reply!
I have dismantled a S2/27 and a S3 2500.
The rotor journals are being chromed to the original sizes and the journal bearing are renewed, so that is not the problem.
What I need is a drawing/scheme of the axial clearances, how to adjust and install. After these 2 compressors, I get another 2 of each.
Gerben
RM-Support.nl
Hi Gerben:)
I know that in the case of a Grasso the factory gives the original rotor oulet end clearance so that you can either judge the wear or set up the new bearings.
I don't think that they have changed the machines since Grasso took them over, so if you have the correct Grassso manual this should do your job.
Kind Regards Andy :)
