R410A outdoor using R22 indoor (non inverter split)
Hi. Is it possible to replace a R22 FCU to a R410A outdoor?
Re: R410A outdoor using R22 indoor (non inverter split)
R22 have 14.3 Bar @ 40 degree C
R410A have 23.3 Bar @ 40 degree C
Equipment should be survive and not start to leak (and in worst case explode) even if whole, non running package heating up 40-50 degree C environment temperature.
So short answer No!, you cannot use same indoor-unit for R22 to outdoor unit for R410A
and even if you try, efficiency should not be good ie. indoor unit for R410A is different optimized (smaller pipes etc.) for higher density working refrigerant.
xxargs
Thanks any chance if to retrofit it?
xxargs
hvac_weng
no just don't.
