2 Attachment(s)
Fujitsu with Siam Comp NH52VNHT
Hi Peeps
I searched throughout the board, though could not locate the info.
Have a failed comp on a Fuj ducted AOT30RMBL an older R22 system using the above Siam NH52VNHT. Fuj spares have the comps no problem, though no longer have the soft starter available, when I checked the same Siam comp is used in Mitsubishi Electric PUH-3VKA though the Mitsu system doesn't use a soft starter only a contactor & run cap.
Can anyone advise any problem in rewiring the Fuj using the same as the Mitsu system?
Thank you for reading.
Attachment 16301Attachment 16302
Re: Fujitsu with Siam Comp NH52VNHT
Mavricks Choice
Hi Peeps
getting over it available, when I checked the same Siam comp is used in Mitsubishi Electric PUH-3VKA though the Mitsu system doesn't use a soft starter only a contactor & run cap.
Rewiring the Fuj ducted AOT30RMBL using the same as the Mitsubishi Electric PUH-3VKA may be possible, but it is not recommended.
