reciprocating compressor bearing wear
Hello everyone. i have read a article regarding to reciprocating compressor bearing wear but something i have don't understand !
The article stated that Temperature of the discharge valve above 350F ( 177°C ) the oil will start to break down, causing accelerated bear wear . The article did not mention whether want to change new compressor oil or remain using after we troubleshoot and solve the problem .Could anybody tell me what should i do when face this type of problem ! Any advice would be greatly appreciated .
oilzee regard
Re: reciprocating compressor bearing wear
When oil reach that temperature it becomes carbonized and smell. You could make oil acid test and check color of oil, and accordingly, change oil and fit burn out filter-dryer in suction and discharge pipe.
In fact, you should proceed like you heaved burn-out.
Hello Nike
Thanks for your help , i m very appreciated
oilzee
Hello Nike
I am glad to help.
Check this bulletin and act as suggested.
http://www.hvacrinfo.com/cope_ae_bulletins/TAE1105.PDF
THANKS NIKE123
For your great efforts
Hi Oilzee,
Might be an idea to send a sample away for analysis. They can tell you carbon content, acid levels, and presence of any wear metals ie bearing, valve, casting, piston rings etc.
I was told by a lubrication chemist that mineral life should be halved every 10c above 80c ie. That`s ok in theory but i`ve not meet a customer yet who`ll pay for that.
Regards,
Glenn
glenn1340
Hi Oilzee,
Glenn
Hello Glenn,
Thanks for your reply , i have no idea where to do this type of analysis in our country . Do any RE ( refrigeration engineer ) members from Malaysia know about this , please give me a hand . You are right , customer may not pay for that .
Oilzee Regards
oilzee ,
This is a very high discharge tempreture . What refrigerant is system on and what pessure / temps is system running ?
Also what type of compressor ?
RANGER1
Hello Ranger1
thank you for helping . i have not been face this type of problem yet . i just want to know more about refrigeration system because my little knowledge just a beginning :o
I wish you all Merry Christmas
[quote=oilzee;129681]Hello Glenn,
Oilzee Regards
Hi Oilzee,
I can`t give a direct link here as I`ve not made enough posts yet but type in "oil analysis services malaysia" to google and you`ll get several situated in Malaysia. I`m sure they`ll be able to help you.
Regards,
Glenn
glenn1340
Regards,
Glenn
Thank you Glenn , good information .
Regards,
Oilzee
