CO2 to clean instalation pipes? is true?
Hello, i am new in this forum, i think is a very good forum to engineerīs us i am. i am from portugal, sorry my bad english...
i want ask ih C02 is good for clean and charge a circuit. i use nitrogene, but i see in danfoss site, i can use CO2, is true? thankīs & regardīs
Re: CO2 to clean instalation pipes? is true?
Hello and welcome to the forum.
Can you provide a link to the Danfoss reference please ?
Brian_UK
No, he cant! He doesn't have 15 posts yet. You should know that as moderator.:D:D
HI i also new in this forum, Well use R141b and nitrogen gas to clean Copper pipe But co2 don't know!!!!!!!
CO2 at atmosperic pressure = frozen dry ice.
CO2 at 21°c = >58 Bar
CO2 generally contains more water than Nitrogen.
You can do it, but unless you have a good reason to flush the system with liquid CO2 nitrogen sounds like a better option.
Steve
use oxegen free nitrogen and your system will be clean and dry
Yes you can clean the pipe but it hard cause the co2 is solid state at atm pressure. And if you just clean it for same kins of gasses to use there is no problem. IF you doing it if the main ref. gasses is another one ex. R410 then you got a problem delivery faster than light. CO2 is sligtly acid and corrord the compressor and other places than contain cupper. That why compressor is made cupperfree cause its break down the cupper and also that layer round the wire in compressor to protect if from shortcut. Hopefully it got some idea eevn my bad eng :-)
Plank!
Steve
Bingo! Nitro grabbeth moisture!
martinw58
It will be dry. But will it be clean?
