First of all, I'm not a native english speaker. So I could do some english mistakes in my post, I'm sorry about that.
Currently, I'm trying to compare the efficiency of several natural refrigerants. I would like to calculate their coefficient of performance to know which one is the most efficient.
I calculated the COP for cooling with this formula:
Attachment 9139
I used the Rankin cycle and I set up the high temperature at 50°C, the low temperature at 10°C and the high pressure for the carbon dioxyde at 10 MPa. I did that to be able to compare those refrigerants. I don't really know if it's a good method or no.
I found those results:
COPc R134a = 5,540709812
COPc R410A = 4,975144092
COPc Propane = 5,398954704
COPc Propylène = 5,370772176
COPc CO2 = 1,326384142
I would like you know what do you think about my approach.
I just found
this paper. Inside the author compares the butane with other refrigerants and I would like to know how did he find the value of the Rankine COP, because it's not really explained in his paper. You can see his results at "Figure 1: Comparison of theoretical capacity and COP for a reverse Rankine cycle without any losses." If someone has an idea of how did he do that? And if you know what is the x-axis, because I have no idea.
Also, I noticed he used the LBF CECOMAF. I know now what is that. But I still don't really understand, because I didn't find any official paper of this norm. And when I check on
this website for example. The LBP CECOMAF could be: CECOMAF LBP, -25/55 °C, CECOMAF LBP, -25/45 °C, CECOMAF HBP, +5/45 °C, CECOMAF LBP, -25/45 °C. So, I'm a little lost. If you know a website where I could find this documentation, it could really help me.
Thank you for reading me and your help!
